3020 flooding
Zog
04-15-2008 05:28:29
I am having a problem with a 3020 gas. Runs fine for a few days and then goes to flooding & missing. I rebuilt carb, replaced plugs wires point & cond. Havent replaced coil. Going to do that next. No new zenith carbs available from deere. Any one out there have an outlet or know some one who repairs them. I cant see any thing wrong with carb but maybe I am not seeing the problem. Thanks in advance.
zog
04-15-2008 20:16:35
 Re: 3020 flooding in reply to Zog, 04-15-2008 05:28:29
Has zenith on it now . Needle valve is not sticking, Replaced twice, float is not sinking as it is not full of fuel. Did not know there is a regulator in the transfer pump. Will check that. Thanks.
Mike M
04-16-2008 12:43:00
 Re: 3020 flooding in reply to zog, 04-15-2008 20:16:35
There are check valves in the transfer pump,but I don't think there is a regulator ? I have had several of the old type apart. Our 4020 got to acting real funny and it turned out it wasn't getting enough fuel through that transfer pump when hot. You may be leaking fuel past the gasket on the needle seat ? I have had this happen on the 2 cyls. before.
Gerald J.
04-15-2008 09:41:46
Sounds like the float needle is sticking open or the float is sinking. Check those for freedom of motion before digging deeper. Could be that the pressure regulator in the fuel pump is sticking and so forcing fuel into the carburetor.
Sloan Express and Shoup parts do have new replacement carburetors. They are not inexpensive.
Gerald J.
Mike M
04-15-2008 05:37:10
Do you have a MS or a Zenith carb. now ? Those Zenith's are by far the better choice and if that is what you have it should be able to be fixed up.
