Best service/repair manuals for JD 1020?
jrschwit
04-14-2008 19:37:13
What are the best service/repair and parts manuals for a late 60s JD 1020? I just acquired a tractor with 1600 original hours.
I am capable of my own maintenance but have always found that good manuals lessen the learning curve. Pubs are available from Deere, I&T and Intertec at considerable price differences.
Any suggestions as to best quality and value?
Thanks,
Jim S.
jrschwit
04-15-2008 18:45:00
 Re: Best service/repair manuals for JD 1020? in reply to jrschwit, 04-14-2008 19:37:13
jdemaris,
Thank you for the thoughtful reply. I'll probably start with the I&T repair manual since they are relatively inexpensive and meanwhile keep my eye out for a reasonable used OEM manual. I'm new to tractor ownership but very familiar with mechanics in general, having done all my vehicle maintenance including engine and trans rebuilds.
I grew up on a farm with a JD model 60, 70, 630, and finally a 4010 when they were first introduced. I was too young then to do any maintenance but sure got to operate them for days on end.
My 1020 came as part of 20 acres that I just purchased. The previous owner may have bought it new (a '67 model) but his maintenance records only go back to '79 although other records refer to a JD tractor as early as '72. He kept sporadic maintenance records, noting work performed and hours reading every few years. I mistyped the current hours above; should read 2600 hours. He averaged 65 hours per year since '79.
Cosmetically the tractor is rough but all the major functions appear to work except lights. I have concluded that all maintenance beyond lubrication was done by friends with much evidence of cobbled repairs. I look forward to gradually restoring it to full function as well as good looks.
Regards,
Jim
jdemaris
04-15-2008 05:22:52
There IS no "best" manual - not under one cover.
Comparing the two manuals is comparing apples to oranges. The IT manuals leave out the "fluff" and just sticks to essential facts. It is a "quick reference" manual and assumes the user alreay has general knowledge. At every Deere dealership I worked at - we always had both manuals for all tractors. IT books are a lot easier and quicker to use - and no big loss if you got one greasy. When we started using them, they only cost $1.50 each. Keep in mind they were originally written for the professional mechanic who already had some mechancial expertise.
I still prefer IT books for most things - and the Deere OEM for more complicated repairs. Even with the Deere OEM manual - you won't get all the info. Deere has a habit of making separate books for certain components - e.g. for injection pumps.
Sometimes you will get some facts in an IT book for a particular tractor - that you will not find in the Deere OEM manual. That's the way it goes. I'll add, that along with the Deere "extra" manuals on eletrics, hydraulics, fuel injection, etc. - IT used to sell a "Standard Units" book. It is a great resource- with a lot of data on carbruetors, starters, ignition systems, clutches, magnetos, etc.
To be specific about your tractor - I have a 1020, a 300, and a 300B - all pretty much the same tractors. I have the IT and Deere OEM books - and still don't always have all the info I want.
msb
04-14-2008 21:08:43
Deere
