'44 JD B Clutch
Nate Wieland
04-14-2008 16:28:44
Folks-
The clutch was slipping on my B. I pulled the adjusting plate off to have a look. Both machined faces look good and so does the lining disc. However, one of the three adjusting bolts can be pulled out about an inch more than the other two bolts. I suspect that's part of the problem. I can hear something inside the belt pulley also.
What is wrong? How should I fix it?
Thanks,
Nate
buck eye al
04-15-2008 14:48:17
 Re: '44 JD B Clutch in reply to Nate Wieland, 04-14-2008 16:28:44
A broken clutch dog can do the same thing. Either way the repair is the same. Pull the pulley off & take a peek before you go buying parts.
Likely you'll have to remove or at least move the left rear wheel way out. Sometimes you can get by removing the rim from the hub if you have cast disk centers. Depends on which way your wheels are on & how big the tires.
You'll have to remove the three nuts, the outer ring with the springs, the floating disk and then the driver disk and inner dry disk.
Remove the clevis pin at the front end of the clutch lever linkage.
Remove the clutch fork by removing the cover from the front of the primary reduction gear housing cover. It's held on by 4 cap screws.
If there's enough clearance between the tire & the pulley, the pulley should slide off the crank.
Before reassembly, remove, clean and grease all the dogs, toggles and the roller bearing. DO NOT use a cold chisel to remove any cotter pins from the clutch dog pins! Make sure all the springs are good. It can be rather surprising to see how much of the springs can be rusted away and what a difference new ones can make in the feel and release of the clutch!
This is all service work the operator's manuals say is to be done in the annual dealer service!
Sure.... that happened didn't it! I know it never did at our farm and now since they're retired it still doesn't happen unless they're apart for some other reason!
Make sure the driver disk is on tight when you're done with reasembly. Check it again after some use too!
It's not really a bad job.
Good luck.
Nate in IL
04-15-2008 17:52:25
 Re: '44 JD B Clutch in reply to buck eye al, 04-15-2008 14:48:17
buckeye al-
Thanks a alot. I dis-assembled. Two of the clutch adjusting bolts had broken heads. They had been repaired either by weld or braze, I can't tell. Bottom line, it didn't last. I will buy 3 new ones. The springs you mention, are they the ones on the back of the pressure plate? Or are you talking about different springs somewhere?
Thanks,
Nate
buck eye al
04-16-2008 14:23:49
 Re: '44 JD B Clutch in reply to Nate in IL, 04-15-2008 17:52:25
The three springs that push the outer plate OUT disengaging the clutch. With the exception of the three flat springs that hold the pulley cover on, these are the only springs in the assembly.
I was so surprised by the improvement in operation and feel of the clutch when I replaced them on my 70D, I went back & bought a set for one of my mid series A's. CAN make quite a pleasant difference if the ones you have are well corroded!
During final clutch adjustment, make sure you rock the bolts back and forth a bit to get the bolt heads to drop into the worn spots of the clutch dog forks. Before you put it together look at the forked end of the clutch dog & you'll likely see an indentation where the old bolt head has ridden many a mile. If the bolt is NOT in that indentation, the clutch operation may be just right. Trouble is, after you run it a while the bolt head will move to and find that indentation and poof..... your clutch will suddenly be loose and may slip. You'll open it up & maybe turn just one nut 1/6th of a turn and it will be too tight. GRRRR! That's because the sum of the dent AND one more flat is too much. I always slide a cotter in but don't bend it then rock the bolts back and forth to find the worn spots before testing lever operation. The only way I know of to avoid this is to replace the dogs or grind the worn spots out. I just rock 'em back & forth. When it feels right (bolts in the pits) then I bend the cotters & cover it back up.
usetabesteve
04-15-2008 10:29:13
You've got a broken bolt, and that puts more stress on the remaining two. Replace all three as a set.
Big Country - IL
04-14-2008 17:17:21
Is the driving disc tight? One of the operating bolts on my '44 B slid out farther than the others - turned out that the head on that one operating bolt was cracking off. Might be the same problem for you - they are still available from Deere, but not cheap...best thing to do is to take the clutch/pulley off and see what's going on inside it.
Nate Wieland
04-14-2008 18:55:19
 Re: '44 JD B Clutch in reply to Big Country - IL, 04-14-2008 17:17:21
What is the procedure for removing the pulley? It seems that I need to remove the driving disk off the crank first? Then what? Do I need to remove the clutch fork?
greenmech
04-14-2008 19:43:50
 Re: '44 JD B Clutch in reply to Nate Wieland, 04-14-2008 18:55:19
Remove the driving disc and remove the clutch fork to get the pully off. Ron Mn.
PBrowning
04-14-2008 17:31:39
There are scads of good use d ones out there. Here's a short list of folks to try calling. As always -- shop by part number! (PatB)
Short Vendor List
Heartland Tractor -- (816) 587-4747
Detwiler -- (715) 659-4252
Shephard -- (715) 265-4988
Marlin Smith -- (712) 489-2570
