3020 thrust bearing question
glsinNY
04-14-2008 08:50:25
I am replaceing rod and mains in standard size in my '64 3020 gas. Called the dealer to get parts, they no longer have the one piece thrust bearing with the collar (#AR49242) available and are superceeding with two piece bearing with thrust washer. Has anyone run into this? If so, is there any drawbacks or issues I need to look for? Any ideas where I may be able to find the one piece JD bearing?
Thanks, Gordon
jjas
04-14-2008 09:33:36
 Re: 3020 thrust bearing question in reply to glsinNY, 04-14-2008 08:50:25
forgot to also mention to put it on the correct way....With the grooves facing the crank and not the block or main cap.
jjas
04-14-2008 09:30:14
use it without worry.
clint315
04-14-2008 08:59:37
i know that toms agri diesel handels the one piece and i think a&i also handle them.
