730 Pony Motor
Grabatire
04-13-2008 19:21:19
I finally found a pony for my 730. Can anyone tell me what the compression should be? I checked this one and it varies from 95 to 108. I'm going to install new points, condenser and coils then rig up a cooling system tomorrow and see what it sounds like and what the oil pressure is. The I&T manual says oil pressure should be 25 to 30 psi, but it doesn't list what the compression should be. The fellow I got it from said I can return it if it isn't up to snuff.
WeirdDeere
04-13-2008 19:28:20
 Re: 730 Pony Motor in reply to Grabatire, 04-13-2008 19:21:19
The compression is supposed to be 110 pounds. So it sounds like you're in good shape!
Brandon
