3020gas
clint315
04-13-2008 14:56:09
we have a 3020 gas tractor with a marvel carb usx36. tractor had a motor job last winter and ever since it is hard to start. acts like it is getting too much fuel. once it is started it runs great. shut it off and starts right back up. leave it overnight and it acts like its firing on one or two cylinders lots of black smoke ,will quit a few times then will straighten out and run great. any ideas???
Gerald J.
04-13-2008 17:22:27
 Re: 3020gas in reply to clint315, 04-13-2008 14:56:09
The float needle valve is probably worn or sticking from gum and varnish. Replace float needle and seat and see if that helps. Tuning the USX carburetor is a real pain, that gives it few friends. There's even a 70s vintage JD Service Bulletin that suggests replacing it with a Zenith carburetor for easier tuning.
While its apart, make sure the float isn't sinking, gas logged, ice crushed, or dragging on the float chamber.
Gerald J.
