4020 synchro clutch
hank n tx
04-13-2008 08:25:58
after tractor has been working for 30 minutes or so, it keeps going when i step on the clutch. i have to hit the brakes and it will disengage.what all will need to be replaced to fix the problem. whats the best technique at bracing the front and back when splitting a 4020. ive split my bro-in -laws 8n before but thats quite a bit of size difference. thanks in advance to any repies.
hankntx
msb
04-13-2008 12:08:06
 Re: 4020 synchro clutch in reply to hank n tx, 04-13-2008 08:25:58
Could be the pilot bearing, a clutch fginger adjustment problem,a broken operating bolt, a loose disk facing,a warped disk or ????
Bob
04-13-2008 18:45:14
 Re: 4020 synchro clutch in reply to msb, 04-13-2008 12:08:06
Don't forget badly worn pilot shaft splines as a possible cause.
ET
04-13-2008 11:19:43
A friend of mine just bought a clutch rebuild kit for his 4020 right from deere. It was a bolt on complete presure plate and disk assembly with new throw out and pilot bearings. The cost was around $750. I used to support the front of a 4020 with a pile of 4x4 cribing and use a couple of jacks, one under each frame rail. The rear end I suport with a rolling floor jack and roll it away from the front end.
