JD 4320 electric fuel shut????
Deerly parted
04-13-2008 05:11:01
Our 4320 was running just fine. After we shut it off for a few minutes and tried to re-start it, it would not start. It acts like it's not getting fuel. If the electric fuel shut off goes bad will they typically not let fuel flow or will they not shut the fuel off? It will crank over fine but just not getting fuel. Yes, I checked and the tank is half full.
F-I-T
04-13-2008 05:57:12
 Re: JD 4320 electric fuel shut???? in reply to Deerly parted, 04-13-2008 05:11:01
This is a "4320, compact utility tractor right? Not the 6 cylinder larger model from the early 70's.
If so, I have a tech manual for the -10 series, and maybe they are close enough in design in this area to help. When the solenoid gets power, it pulls in to permit fuel flow to the pump. You should be able to hear an audible "click" when you turn the key on. I did have one that was stuck one time on my 855, and I tapped on it and it released. That was five years ago, and it never stuck again. So, you might try a GENTLE tap or two if you can't hear it click.
Here's a slice of the testing of the solenoid. Again, this is for a -10 series CUT.
Hope this is applicable, if not, disregard.
Frank
third party image
Indiana Boy
04-13-2008 05:51:29
Our 4620 did the same thing a couple years ago. We shut it off at noon. When we went to start it up again it would just crank and wouldn't start. It has the same fuel shut off system as a 4320 and it went bad. Had the shut off replaced and it started right up.
jd40an
04-13-2008 06:31:10
 Re: JD 4320 electric fuel shut???? in reply to Indiana Boy, 04-13-2008 05:51:29
Our 4620 did the same thing many years ago. Shut it off at noon & after lunch wouldn't start. As a last resort, I tapped the solinoid & presto! worked like new again & has never done it again--go figure!!!!! !
