two cyl trans
Bigblock
04-12-2008 21:39:45
Are the 730 trans naturaly loud because of the straight cut gears? All two cylinders had straight cut gears are all of them loud?
Bigblock
04-13-2008 07:23:00
 Re: two cyl trans in reply to Bigblock, 04-12-2008 21:39:45
Thanks for the reply guys.I've just replaced all the bearings and it sounds like a loud electric can opener,lol.I used 90W .
wilamayb
04-13-2008 17:20:02
 Re: two cyl trans in reply to Bigblock, 04-13-2008 07:23:00
Some GL1 140 may help to make it a little quieter. The thicker the better since there is no pump involved. As long as it will flow it is not too thick.
To answer your question... It is as the others say two cylinder transmissions are only noisy as they become worn. I have a 720D and a late B that make no noise at all, all the while I have a 620 that whines anytime it is in load.
Mike M
04-13-2008 11:31:19
Something might be installed incorrectly and rubbing ? Is this noise all the time ? Only in certain gears or going up or down hill ?
Mike M
04-13-2008 04:42:09
A good one normally isn't very loud. If you go looking likely you will find alot of problems in there. If you go in and fix all the problems and worn out bearings there is still a good chance it will still be noisy from wear patterns,but at least you know it's in good shape otherwise. Fenders help amplify the noise too.
2cylinderlp
04-12-2008 23:33:41
The gears are "straight cut" but actually have a bit of a radius on the sides of the teeth. So that way thay they can efficiently roll against each other and not be too noisy. In a high time tractor the primary reduction gears which run the fastest and get used the most can wear to a somewhat flatter profile. Then they can be a lot more noisy as the gear teeth slap against each other. If the primary reduction gears are worn they will be a lot more noisy when the tractor is pulling up a grade versus coasting down that same grade. That is of course because the "pulling" side gets used a lot more. I think 630's have a little more natural tendency to be this way, probably because of sound harmonics in the gears or some of the castings. I have one that really howls. But I wouldn't say the 2 cylinder transmissions are all excessively noisy. Different gear speeds sound differently. A transmission that is in good shape will produce a mild set of tones that almost harmonize with each other. I don't mind that sound at all. Other wear on bearings and gears certainly can produce more noise. But it is surprising how poor the general condition of some of those trannys can be and still function normally with not too much noise. Some owners have gone to straight 140W gear oil to try to minimize tranny noise.
