46 B Starting Issues
JD Gimpl
04-12-2008 13:26:48
Hello,
I have been trying to get this going since it stopped running 2 weeks ago. New Mag, Rebuild Carb and still nothing. When I pulled the carb water ran out of the intake end, rain must have gotten in. Now I noticed that there was a grey drip from underneath and i have water in the oil. To top this off I pulled the new plugs and they had black oil like deposits.
Is it possible that there was so much water in the motor that it was getting into the cylinders and fowling everything?
Any other suggestions on what might be wrong?
Thank you JD Gimpl
JD Gimpl
04-13-2008 13:04:18
 Re: 46 B Starting Issues in reply to JD Gimpl, 04-12-2008 13:26:48
Radiator is full. Don't see any signs of a crack. I have let everything sit out, took plugs out ecetra.
Going to get oil and then give it another try.
d. coleman
04-12-2008 21:18:19
im not sure about your model "B" but my 51 the pushrod tubes in cylinder head pass through water jacket if these are leaking that just might be the sourse of water entry into crankcase, also one intake manifold stud hole is open to water jacket. good luck. d. coleman
Gary from Muleshoe
04-12-2008 14:57:37
Have you removed the breather oil cup. I had a similar problem one time on 1940 B after a hard rain and when I removed the oil cup it was full of water. Once it drained out, and I cleaned the plugs, it fired right up.
garytomaszewski
04-12-2008 19:07:19
 Re: 46 B Starting Issues in reply to Gary from Muleshoe, 04-12-2008 14:57:37
Not sure how much rain you've had but if stock breather you would have to fill air cleaner to hood level to get water into carb, water in the oil too, makes me think you may have a cracked head. Is the radiator full?
