JD 520 Disk Harrow--what size to buy?
Tbolt76
04-12-2008 12:46:17
My Aug. '03 article lists the following model harrows to pull behind a 520 as "matched working equipment". Any help on the size of these models???
KYB, KBA, FW, or JBA disk harrows
S single action disk harrow
416 offset disk harrow
1200 series offset disk harrow Sorry if this seems too elementary, but my access to green mags is limited to my dad photocopying stuff and mailing it to me. thanks.
Rick Kaufmann
04-13-2008 12:36:03
 Re: JD 520 Disk Harrow--what size to buy? in reply to Tbolt76, 04-12-2008 12:46:17
Tbolt:
I have a JD, RW, 9' wheel disc (9'-10" actual cut) that I use with my 1959 JD 530. It pulls well in 3rd gear in my plowed gound, which is mostly level, sandy loam. It has 32, 16" blades, 8 per gang with 7 1/2" spacing. This disc was originally sold as a match for the 50,60,70 series tractors. Pulling an 8' drag in tandem with the disc, I would'nt want to have anything bigger for a 520/530. The RW is a solid frame disc. Blade angle is always at maximum and can't be varied. Depth of cut is controlled by moving the transport wheels up or down with the cylinder. I'm not familiar with the other discs you list, but I would think that the offset models may be a bit much for your 520. In a tandem model any disc between 7'-10', depending on soil type should work for you be it either a drag or wheel disc.
Rick
Tbolt76
04-13-2008 19:00:25
 Re: JD 520 Disk Harrow--what size to buy? in reply to Rick Kaufmann, 04-13-2008 12:36:03
Rick, Interestingly enough, I'm on sandy loam soil as well. After checking out some photos of other discs on this site, someone trying to ID one was directed to JD's online Parts Catalogs. So I took my Aug.'03 Green magazine's 520 matched parts suggestions and searched for all of them and got a good idea of what types of discs they were. I have basically come to the conclusion that I can comfortably get away with and 8' 3pt disc, probably 20" blades fairly well. I don't want one of those cheap angle iron discs you see at the local tractor place. Have to buy a good one that weighs 900-1000lbs. By the way, how do you think the 3pt mount disc would compare to a wheeled transport disc in terms of load on the tractor while pulling it? My neighbor has about a 9 or 10' JD transport disc that's been sitting for years and I'm thinking about buying if he'd sell. Tom
Rick Kaufmann
04-14-2008 15:54:54
 Re: JD 520 Disk Harrow--what size to buy? in reply to Tbolt76, 04-13-2008 19:00:25
"T"
I have never pulled a 3 Pt. disc with my 530. Most of the 3 Pt. discs I've looked at are rather light and would require adding weight of some sort to get them to cut very well. The only 3 Pt. implements I use with the 530 are a JD 810, 3-14" plow and a 6' Sidewinder bush hog. Both are probably in the neighborhood of 500 lbs. give or take, and my tractor carries them (in transport, w/no extra front weight) well, but I usually have a 45 Loader hanging off the front also. My plow manual recommends 60 Lbs. front weight (with Roll-O-Matic dual wheel front end, 105-110 dual front w/o Roll-O-Matic or single front wheel. I would check out your neighbors disc asap. Probably can get it for less than a newer 3 Pt. model. What type/model is it? I think you will be happier with a transport or heavier drag type disc with adjustable angle.
Rick
Dean in iowa
04-12-2008 17:23:21
I have a nice original JD RWA 7 ft wheel disk. It would be a perfect match for your 520. E-mail if interested. Thanks
