JD 2010 gas engine
Tommy Lykins
04-12-2008 07:40:54
I need a gas engine for the 2010 Is there any hope of finding one anywhere?
edj856
04-14-2008 09:01:49
 Re: JD 2010 gas engine in reply to Tommy Lykins, 04-12-2008 07:40:54
There is one on e bay right now, not sure if it is running or not though.
Tommy Lykins
04-14-2008 21:15:12
 Re: JD 2010 gas engine in reply to edj856, 04-14-2008 09:01:49
Thanks I'll check
ben brown
04-12-2008 15:46:16
old. i have a late model 2010 ind. the power steering housing under the radation is cracked you wouldn.t have one of thies housing .
Tommy Lykins
04-12-2008 20:21:07
 Re: JD 2010 gas engine in reply to ben brown, 04-12-2008 15:46:16
No I sure wouldn't. I 'm just starting this JD and All our old stuff is Farmal & A/C
jdemaris
04-12-2008 13:19:13
They are usually pretty easy to find. Last time I went looking, I found over 20 of them in just a few days. Many Deere combines used those engines.
Tommy Lykins
04-12-2008 20:22:15
 Re: JD 2010 gas engine in reply to jdemaris, 04-12-2008 13:19:13
Thanks loads I'll Look at equiptment
buickanddeere
04-12-2008 11:09:26
Can you find a belhousing and 2-53 from a scrapped 440 industrial? Same Dubuque two cylinder bolt pattern.
old
04-12-2008 08:58:55
I have a bunch of parts for one. I have the block crank shaft, head and most of the other stuff need to put one together. E-mail is open
Jon Holman
04-12-2008 08:21:09
Have been several on ebay. Mcgrew equipment in Milford IN. would be another source.
