I'm fairly sure a 7020 is built like a 7520 and the 30 & 40 series 4WD tractors. {But I haven't had a 7020 in the shop since 1980} The standard method for access to the engine: Drain and remove the fuel tanks, split the side frames and the front axle away from the front hinge, then you can pluck the engine and clutch off of the clutch housing. You'll need lots of blocking and lifting equipment. Make sure the hinge can't rotate. Anything that gets away from you can get you hurt or killed. Wasn't what you wanted to hear, was it? There is a lot labor involved with fixing these old tractors up. But is it possible to get the pan off without all of this? ....Hmmm.... Do some rough measuring/estimating around the oil pan area. When removing the pan, it has to come straight down for about the first six inches. This is needed because the oil pump and pick-up extends down and very close to the rear of the pan. Then you might be able to twist and wrestle it out of the way. Sounds like a tough, dirty, and painful adventure to me. If you are able to get the pan off, would you be kind enough to post back? Customers are always asking me what is possible and what isn't.
