Checking Hydraulic pressure
jd2140
04-11-2008 21:28:55
I recently got a pressure gauge you plug in your back hydraulic hookups on a JD tractor to check what pound pressure your tractor is putting out. The 2 deeres i have is supposed to be at 2300 PSI, well one tractor is, but the other one, which is a 2140, is only reading about 1800 pounds at 1500 RPM's, but if i drop it down to 1000 RPM's to check it like the mechanic said to do, it barely comes up to 500 PSI. I'm wondering whats wrong and why its doing that, i just had the mechanic rebuild the tractor in the lift area, all new clutch and hi lo discs. I know how to turn up the pressure on the front pump but not sure why its showing such a low number then makes a big jump with such little RPM change.
