JD 40 propeller shaft pin
J Chantry
04-11-2008 19:13:57
1953 JD 40 - the propeller shaft came loose at the transmission input shaft. Split the case and found the pin (that goes through propeller shaft and transmission input shaft) had snapped and worked loose. Tractor has about 8 hrs since rebuild. I had used a 3/16" solid pin peened on both ends.
Is there a better way to pin this shaft?
Thanks for any help you can give me.
d. coleman
04-12-2008 11:36:15
 Re: JD 40 propeller shaft pin in reply to J Chantry, 04-11-2008 19:13:57
i think i must hav a bouges parts book. this isnt the first time i seem to get the wrong info. is there a different pub. co.? i checked a friends manual, and it was different. sorry, d. coleman
LA-man
04-12-2008 05:14:28
My "M" service manual says to use a pin, headed on one end, with a washer on the other, peened over but left loose in the hole so the pin is not torsionally loaded. The pin may be available from JD. I don't see how the prop shaft could travel forward far enough to come loose (about 1 1/2 inches) unless you have a flywheel bearing problem.
d. coleman
04-11-2008 21:00:15
what about your pilot bearing in flywheel? did you renew it at overhaul? if so is it properly installed, if not seated fully it could cause propeller shaft to push rearward putting said pin in a bind. also my "M" parts book calls for a split or groved pin in "MT", M doesnot show pin installed. just my two cents. good luck d. coleman
jCarroll
04-11-2008 20:44:46
Pin procedure sounds OK to me. A spring pin should be harder, and would not require peening once in place.
For that pin to break you must have some bind on the throwout bearing or clutch disc.
