1939 H Serial Number
Jimmy D.
04-10-2008 20:28:41
I have located a John Deere H tractor with a Serial # plate on it but it has only H and no number and has patent pending on the plate. Did John Deere have tractors like Farmall that were demonstators before serial numbers were issued? If not why would there be no numbers, just the H? I was told it is a 1939 model.
PBrowning
04-10-2008 22:56:56
 Re: 1939 H Serial Number in reply to Jimmy D., 04-10-2008 20:28:41
Jimmy -- Every tractor leaving the Deere factory had a fully completed serial plate. There are lots of clues to tell us something abut the tractor, and to tell approximately what serial number would have been assigned.
The serial plate situation you describe sounds like the plate is made of steel rather than alumminum. A 39-H would have a tag made of aluminum. Steel tags were used later, during WW 2, because aluminum was in short supply -- needed to build airplanes.
The '39-H has many features that distinguish them from all other "H" tractors. You are invited to visit the John Deere "H" Restoration Site (below) where, over on the far right, you will see a heading SPECIAL INTEREST. From the drop-downs select 39-H and there you will read some about that special year, and also some about the lowest serial numberd "H" in existence.
Also -- feel free to call or write to learn more the one you have found. (830) 627-0430. (PatB)
