6400 jd
Chad in Mn.
04-10-2008 19:24:42
I have been looking at a 6400 with a power quad transmission. The tractor has about 5500 hours on it, does any one know of any tranny trouble with this setup? thanks
Kevin Schmidt
04-11-2008 15:16:20
 Re: 6400 jd in reply to Chad in Mn., 04-10-2008 19:24:42
I had one, have the tranny pressures and filters checked. I was told when the wear clearances start to open up when the clutches start to wear, the tranny pressure drops fast. The one I bought pulled ok when cold, but after running an hour wouldn't pull itself. I talked to a lot of people in the know and expect to do a rebuild on a powerquad every 6-7000 hours depending on use. I also found out when they start to go, they die fast.
Chad in Mn.
04-11-2008 21:10:12
 Re: 6400 jd in reply to Kevin Schmidt, 04-11-2008 15:16:20
thanks for the reply.
