Just for a little clarification... "Expo quality restoration" is one of those terms that is not defined by all in the same fashion. Expo tractors are typically very original tractors that are approved by the folks that coordinate expo. Normally you wont see tractors with brush paint jobs and alternators at expo. That's not to say that some people that say have "expo quality" restorations have tractors that would ever be accepted at expo. To help you better understand.. The term is tossed around and used incorrectly almost as much as the term I hate most "restored". I always ask "resored to what?" the worn out tractor it has been for years... As for the manifold. You can certainly purchase and aftermarket mainifold, which is what you will get at Deere at this point. I have heard bad reviews on some of the Deere manifolds. I'm not sure if that has been corrected or not. The only other option I would consider would be an NOS manifold which may take some time to locate, as well as cost a pretty penny. Many expo tractors have aftermarket manifolds installed. Good luck with your work! Please always remember that "restored" does not mean "I fixed the leaks and put on a new manifold with a paint job." Restored means you checked gears for backlash, replaced bearings and seals. The term came from "restored to its original factory condition"
