34 A Axle Seal Search
DScott
04-09-2008 08:11:31
I need the axle seals for a 1934 A I am working on(SN412XXX). I am trying to get all of the parts rounded up before I go into it. The seals I need are AA487R which subs to AA506R. According to JDParts they are both NLA. Anybody have any ideas where I might find these?
Thanks.
Duane Larson
04-09-2008 11:23:53
 Re: 34 A Axle Seal Search in reply to DScott, 04-09-2008 08:11:31
Don,
I show the conversion from AA487R to C-R 27600, which lists at Motion Industries for $27.96. My old C-R book shows this fitting a shaft of 2.750, a bore of 4.249, and a width of .438.
DScott
04-09-2008 11:41:54
 Re: 34 A Axle Seal Search in reply to Duane Larson, 04-09-2008 11:23:53
Thanks Duane! I will call the local MI warehouse and see if they have them.
Don
wilamayb
04-09-2008 08:57:34
Any bearing supply should be able to help you out if you will supply them with your old one. I purchased some a few months ago for an unstyled A at Car-Quest. I'm sure Napa would also be able to assist you.
DScott
04-09-2008 09:30:03
 Re: 34 A Axle Seal Search in reply to wilamayb, 04-09-2008 08:57:34
I have done that before and might have this time but it seems that the parts houses in my area now are staffed by kids that only know how to look up something by the vehicle model on the computer. If it isn't a part for a late model car that's listed in their computer their eyes glaze over. If I tell them I'm working on a tractor they say they don't carry tractor parts. I went in looking for a bearing awhile back and they claimed they didn't carry it (tractor stuff). Someone on the board told me that it was the same bearing used on a 1957 Chevy wheel bearing. The first place's computer didn't go back to 195. The 2nd place looked it up in a book and they had it on the shelf. But they never would have found it just going by the bearing specs. All of the old locally owned old school parts houses have been shut down or bought out by the franchises. Maybe this is a local problem. Sorry for the rant, I feel better now.
OLTWOPOP
04-09-2008 09:47:23
 Re: 34 A Axle Seal Search in reply to DScott, 04-09-2008 09:30:03
DScott,
I found this in an old post hope it helps.
Randy, I"m restoring a 1934 "A" also. I just replaced the rear axle oil seals last week. I realize that Deere made lots of modifications in the first year of "A" production so mine may be different than yours. My serial is 410065. The oil seal is at the outer end of the axle just inside of the felt seal. When I learned that J Deere no longer had the seals available I visited NAPA. They provided part number 32397. An exact duplicate of the size of the original. It"s a perfect fit. Cheers!
David
DScott
04-09-2008 10:10:41
 Re: 34 A Axle Seal Search in reply to OLTWOPOP, 04-09-2008 09:47:23
OLTWOPOP, Thanks, but at SN 411592 they changed the seal stock number from a AA502R to an AA487R. Then at SN 413648 they changed it again. Mine is the middle type setup. So I need a AA487R type seal.
Thanks,
Don
