The filter is in the suction side of the system, and is a wire-mesh screen that can be cleaned with lots of solvent and compressed air. Changing the filter MAy help, but that lift is a unique mechanism, with LOTS of things to go wrong, besides the possibility of a weak hyraulic pump. The steering is operated by a priority valve that takes a few GPH for the steering FIRST, then lets what's left go to the hitch, so if the pump gets low on flow, the lift will screw up BEFORE the steering fails. I'm NOT sure when they changed from the short to the long filter. There were LOTS of changes made around the 20-some thousand serial number. I'm not sure if it may have been possible to update the older units to the longer filter setup??? There is a rubber gasket that seals the inside end of the filter to the oil pump intake manifold. Make SURE that gasket is in place, and in good condition, or the filter doesn't do much good. The diesel was built by Deere in Dubuque. CUTE little fella, ain't it! (Aleast until it fails!)
