JD 4430 leak
TOPsJD
04-08-2008 19:35:11
my 4430 tractor leaks hydrulic oil from what looks like the pump front of tractor, it doesnt look like any connections leaking it looks like out of the seams of pump is that possible or am i not lookin in rite places
4430jd
04-09-2008 03:26:37
 Re: JD 4430 leak in reply to TOPsJD, 04-08-2008 19:35:11
Mine just this weekend did the same thing after looking at determined seal on shaft is leaking, It sat all winter dont know if that anything do do with it, Must be popular issue Deere had the seal O-ring in stock, Now to fix it is next issue, But definitely check it as thoroughly as you can, Other one we have the 1/8 inch line broke was much easier fix
Bob
04-08-2008 19:43:52
There's about 3 dozen places those pumps can leak, not to mention the cast iron housings crack from time to time.
Get it CLEAN, and CAREFULLY look for a leak.
DON'T stick hands/fingers up there while it's running 'casue of the risk of high pressure oil penetrating your skin!
