JD 50 govenor?
JDman21
04-07-2008 17:26:18
My 50 isnt running right. It idles good and I push the throttle ahead and it doesnt accelerate til the lever is about straight up. I unhooked the linkage to the carb. and meesed with the throttle by hand and it works fine. So I hooked it up and went for a drive and again it didnt accelerate til half way. Also while I was driving the tractor would speed up and slow down on its own. Any ideas?
Duane Larson
04-07-2008 19:17:01
 Re: JD 50 govenor? in reply to JDman21, 04-07-2008 17:26:18
JDman21,
When you disconnected the linkage and operated the butterfly by hand, did you also hold the governor rod and see if it advanced and retracted smoothly? I suspect it did not, and a look into the governor seems reasonable. However, first check the linkage - with the throttle lever wide open and the butterfly wide open, the governor rod needs to be about 1/2 hole short from going in the carburetor butterfly. Remember to remove the distributor before removing the LH governor cover as they will become disconnected as the governor shaft spring pushes the distributor drive away from the distributor. There is a JD service manual for the 50 - SM2010 which will help if you decide to pull it apart.
John Van Valkenburgh
04-07-2008 18:00:17
There is a procedure that the factory uses to correctly adjust the throttle linkage. I don't have the manual with me just now, but I can look it up if you wish.
Be sure the linkages are correctly adjusted before going into the governor. I agree with the other post you got, if its not a linkage adjustment thing, its likely to be the governor.
Best of luck,
John
1953 Model 50
RobMD
04-07-2008 17:35:33
I think your governor is kaput. It's supposed to act almost instantly... like from a slow Putt...putt..putt and you shove the lever forward, and it'll blow a little black smoke and puttputtputt away... something seems to be wrong with the weights in there.
