D. Coleman, PBrowning and WillP Answer to my piston Question
Kris A NC
04-07-2008 10:06:04
My brother stopped by and measured my pistons today. He said they measured out at 4.275. So as Mike M stated they look to be .030 over, just a little under. Would the way to go be to get .030 and file them down? I assume that would be the way. Or is that what the pistons need to be to qualify .030? Thanks! Pat I will probably be calling the gentleman you recommended!
Kris A NC
d. coleman
04-07-2008 17:48:32
 Re: D. Coleman, PBrowning and WillP Answer to my piston Q... in reply to Kris A NC, 04-07-2008 10:06:04
glad you are seeing a light at the end of the tunnel, also my thanks to F-I-T for info on OTTO GAS ENGINE WORKS, sounds like great web sight to file away for futher refernce. enjoyed the chat, sorry i wasnt much help. d. coleman
Kris A NC
04-08-2008 03:46:00
 Re: D. Coleman, PBrowning and WillP Answer to my piston Q... in reply to d. coleman, 04-07-2008 17:48:32
I enjoyed the chat as well Mr. Coleman. I will post pictures when I get her done and running again. Thanks again
Kris A NC
Mike M
04-07-2008 11:11:13
You say he measured the pistons. That would make sense then as the pistons NEED to be smaller than the bore diameter ! Check with a JD dealer and have them run the old ring set number on the locator. Hastings will even sell them direct to you and likely have a pre packaged set. But you will now pay retail. Try Hinrich's repair also he has ads in green magazine.
Kris A NC
04-07-2008 11:18:52
 Re: D. Coleman, PBrowning and WillP Answer to my piston Q... in reply to Mike M, 04-07-2008 11:11:13
Thanks Mike!
F-I-T
04-07-2008 11:23:38
 Re: D. Coleman, PBrowning and WillP Answer to my piston Q... in reply to Kris A NC, 04-07-2008 11:18:52
If you can't get a Hastings cross for that ring set (.030" O/S for that "B" was part number B601), you might try Dave at Otto Gas Engine Works. He makes custom ring sets, and can modify an existing set if necessary. He will even sell you one ring at a time.
Here's a link:
Kris A NC
04-07-2008 12:21:15
 Re: D. Coleman, PBrowning and WillP Answer to my piston Q... in reply to F-I-T, 04-07-2008 11:23:38
My rings are on their way. Thank you very much! Dave is a great person to deal with and knows his stuff. I appreciate the help again frank.
Kris A NC
Kris A NC
04-07-2008 12:00:52
Thank you for the info and the Otto Gas Engine Works contact. I really appreciate it Frank!!
Kris A NC
Kris A NC
04-07-2008 10:55:46
 Re: D. Coleman, PBrowning and WillP Answer to my piston Ques in reply to Kris A NC, 04-07-2008 10:06:04
Pat,
Russ couldn't help. he says he only sells the whole kit and not just rings. So I will start looking through my Green Magazines and Two-Cylinder to find someone who might be able to help.
Kris A NC
