1942 John Deere B Power-trol
Wendell Filkins
04-07-2008 06:20:31
With the cutch engaged,power-trol in gear ,oil level full, arms do not move.
jd40an
04-07-2008 09:21:40
 Re: 1942 John Deere B Power-trol in reply to Wendell Filkins, 04-07-2008 06:20:31
Your '42B originally came equipped with "Power Lift",which gave rockshaft up or down only, operated by "kick pedals" & no hyd outlets. There is a John Deere kit to convert a "Power Lift" valve body to have position control of the rockshaft. These dispense with the foot pedals & typically have a lever on the right side, but I've seen them bent so they can be used with the left hand. If a later "Power Trol" valve body has been installed on your tractor there will be a lever, usually on the left side & two removable "plugs" on the back towards the right side of the valve body that are used as outlets for a remote cylinder. It would help if we knew exactly which setup is on your tractor. There is a good chance that your rockshaft is already in the raised position as they don't usually go down without some weight. You can check for this by leaving the PTO out of gear, putting a large pipe wrench on the rockshaft square & Pushing down while holding the lever back, or "tripping" the foot padals. Good luck!
georgiahayfarmer
04-07-2008 18:31:51
 Re: 1942 John Deere B Power-trol in reply to jd40an, 04-07-2008 09:21:40
The arms will not move down unless they have weight on them. So if you put a big pipe wrench or what have ya on the rockshaft and trip the pedals once, try and pull down on the wrench. If it doesn't work, trip the pedals and try again. Ya stand on the pedal once to go up and then again to go down. Pull the cap off the top and look down in the housing with a flashlight and check your oil level with the pump running. You should see it swirling around in there. Be careful of that spinning pto cause it will rip your pants right off even with a guard installed. If your rockshaft hasn't moved in a while then you may have to play around with it and the pedals to try and get everything free again.
Scott
The JD Workmen
04-07-2008 06:49:23
Do you have the dummy plugs in or the hydraulic plugs. You need the dummy plugs for it to work.
