148 Loader Attachments
powerhouse
04-07-2008 05:42:06
I have located a 148 loader that I intend to purchase and mount on a '69 4020 Gas Synchro. Should work great for moving/stacking hay bales and the like.
Does anyone know if attachments for newer JD loaders like the 600/700 series are compatible with the 148? I found a new bale spear for a 640 loader that, if compatible, would make a nice addition for hay season.
M w J
04-08-2008 17:58:12
 Re: 148 Loader Attachments in reply to powerhouse, 04-07-2008 05:42:06
If there is such a thing as a insert frame reinforcement How can it do any good It would have to start and stop on either side of the bolts that go in to the engine block. Or else the frame would be wider then the loader brackets would be 2 wide for the loader My 148 Has a 1/2 thick plate that extends from just ahead of the back engine mount bolts to ahead of the radiator above and just ahead of the rear widefront mounting bolts then it has the 2 in tube that goes to the front of the tractor and mounts to the front . I may be yelled at But I do not Think that JD had any such reinforcement They do have the one under the oil pan to tie the right and left side together. And I have to say if someone broke a siderail on a 4020 using a 148 or 158 It had to be more then abuse it had to be neglect from useing with loose bolts. Some people can wear things out driving down the road.
Tx Jim
04-08-2008 04:12:50
[quote="Gerald J."](quoted from post at 00:07:32 04/08/08) I have two manuals for 148/158. Edition J3 does not show the insert. I don't know where the other one is and I can't disturb the piles its probably in too much until I finish the Ides of April.
Gerald J
I agree with Mike M will you please post the part #'s for these side re-inforcement plates as in all the JD loaders I mounted on Waterloo tractors in the past must need them. I never saw any mention of these plates in mounting instructions when I worked for a JD dealer.
Thanks,Jim
SDGREEN
04-07-2008 20:04:19
MDS is located in Parkston SD and I have checked with them before on the same thing you are doing and unfortunately they do not make a QT to accept the newer attachment you found. They can however make your bucket QT and sell you a bale spear, pallet forks, and other attachments that they manufacture. Great quality stuff too. Hope this helps you.
powerhouse
04-07-2008 15:55:08
Thanks all for the replies. I was wondering if the beam spacing was different.
I'll check out the Sur-Lock setup and also look into rail reinforcements. Definitely don't want a case of the twisties.
Mike Aylward
04-07-2008 13:59:17
Powerhouse, the newer loaders, in addition to the different attachment method have a wider beam spacing than the older loaders. The Sur-Lock system works pretty well and will make it much easier to mount different attachments. I made a similar setup for my 158 and it gets used almost daily. Mike
JMS/.MN
04-07-2008 08:59:21
There is a quik-tach system available for the 148 loader- made by Sur-Lock. Made by mds mfg. google finds it. Had one for over 20 years.
Gerald J.
04-07-2008 08:29:40
Be sure to get the side reinforcements (hidden from view) for the 4020 side rails.
Gerald J.
Mike M
04-07-2008 16:01:54
 Re: 148 Loader Attachments in reply to Gerald J., 04-07-2008 08:29:40
So hidden from view JD doesn't even show them in their parts books ? If you have a valid part number for these please post it.
Gerald J.
04-07-2008 21:07:32
 Re: 148 Loader Attachments in reply to Mike M, 04-07-2008 16:01:54
Gerald J.
Santa Claus
04-07-2008 07:55:43
I have just been through where you are now. I bought a 148 to put on our 3010 Diesel. The 146, 148 and 158 loaders are all pin mount buckets etc. All the attachments I am finding for sale that fit on the newer loaders are set up for quick-tach. Check out the mounting arrangement before looking and buying.
