37 d magneto swap
josh kuhn
04-06-2008 20:21:59
can i put a wico flange mount mag in place of the original edison splitdorf and if so what do i need to do to make it work. thanks
john deere guy
04-09-2008 14:32:16
 Re: 37 d magneto swap in reply to josh kuhn, 04-06-2008 20:21:59
I did this on my 41 D. Used key stock brazed onto drive to extend it. Timed it and the tractor and bolted it on. No problems for 10 years.
Duane Larson
04-06-2008 21:07:24
Josh,
Yes, you can use either a Wico C or Wico X series magneto. You need a Wico C477, C1042, XH477 or XH1042 magneto, but make sure it has a long-lug drive cup. To see the difference, go to www.robertscarbrepair.com and there is a picture comparing long and short lug drive cups. If you have a choice, I would go with the Wico XH series as they have several improvements over the C series.
Timing them is easier than the Edison as they provide a spark at each impulse. Remove your spark plugs, connect them to the magneto, and lay the plugs on the tractor to provide a ground, but away from the hole you removed them from so a spark doesn't ignite the air-fuel mixture which can be ejected from the plug hole. Turn the flywheel until the flywheel side is coming up on compression (you'll feel a pressure on your thumb if you hold it over the plug hole), then turn until the LH IMPULSE mark on the flywheel lines up with the mark on the transmission case. Around that time the magneto will impulse and provide a spark to a plug - put the plugs back in and connect the wire to the plug which sparked to the flywheel side (and the other wire to the plug on the pulley side), and you should be ready to go (or do a more accurate timing with a timing light - the archives have a lot of info telling how to do that).
