46 B Mag or Carb Problem
JD Gimpl
04-06-2008 19:14:04
Well I Started up the 46 today and it ran for about 45 seconds and then sputtered and died. Now I cannot get her going. I checked the mag and I get spark to the plugs, I pull the plug wire and hold it 1/4 inch away from frame and I get a spark. So I don't think it is spark issue.
I pulled the carb DLTX 67 and when I loosened the bolts from the air cleaner side a bunch of water poured out. I went ahead and took the carb off and have ordered a gasket kit from Roberts. I took the carb apart and there was a bunch of rust inside the bowel so I have been cleaning it with brake cleaner to get it clean.
Is there anything special about putting the carb back together? I was just going to blow it all out and then reassemble it, it seems simple so I am a little leery that I am missing something.
I would appreciate any advice you folks would have.
Thank you, JD Gimpl
Jon Hurley
04-07-2008 04:43:32
 Re: 46 B Mag or Carb Problem in reply to JD Gimpl, 04-06-2008 19:14:04
I had problems with my DLTX67 carb as well. The info that Pat has sent you will serve you well as it did me. My 41B runs like a top now.
PBrowning
04-06-2008 19:44:42
The carburetor is key to a running Deere! For more basic information, go to the JD-H site (below) and whence there, scan across to ARTICLES 1, and from the drop-downs, select CARBURETORS.
Big Country-IL has advised you well. In the article I've sent you to, be advised that the narrow passageways were drilled through cast iron a half century back. They were also treated to resist rust. Well, with the passing of time, that treatment has withered and rust has taken over. Delicate passageways now closed by rust need to be cleaned and done so with very deliberate care -- for if you make any of the orifices larger than original design, the carburetor will be altered, and may no longer ever work as it should. Treat that very valuable gem with due diligent care. (PatB)
Big Country - IL
04-06-2008 19:26:14
Make sure all the little passageways are clear (Roberts has special drill bits for it - run them in by hand, not in a drill). Roberts also has some technical information on the passageways on their website...
