Couple of 4020 questions
Illinois Adam
04-06-2008 17:35:18
Recently bought a 4020 diesel powershift (66), and it's got a few problems I would like to take care of before using it.
Well first off the throttle is acting goofy, when I start it up it revs way up, and acts real strange.
Second the shifter linkage is very very sloppy.
I tracked down the source from the shifter down through the pedistal past the brakes, and it ends up being in a box below the platform on the right side.
can I take that box off without spings and parts flying everywhere?
How much is a injector rebuild?
Best place to send it?
Thanks for looking
Adam
JMS/.MN
04-06-2008 19:31:55
 Re: Couple of 4020 questions in reply to Illinois Adam, 04-06-2008 17:35:18
Some of those shift lever linkage parts right under the cowl have replaceable bushings. Some wear spots can be built up with weld and ground down to original. Throttle problem does sound like the pump. My 3020 did that, rebuild was done by Diesel Specialties in Southern MN- 1-800-966-2198. Cost around $700 in late 90s.
Gerald J.
04-06-2008 17:47:16
The speed problem is probably the Roosa pump. There's a plastic governor ring that deteriorates and next it plugs up the fuel return line. Takes a pump rebuild. I've read of them costing as much a $500.
Don't know about the PS linkage. Looking in my parts catalog, I see several links, levers and bell cranks between the shift lever and the push pull cable and a couple more in the PS shift control valve (and some springs). Its quite possible all those pivots and clevis pins (as well as the holes they operate in) are worn contributing to the looseness. And if the sheath of the push pull cable isn't anchored that will add to the confusion.
Gerald J.
JMS/.MN
04-06-2008 23:02:55
 Re: Couple of 4020 questions in reply to Gerald J., 04-06-2008 17:47:16
Sounds exactly what mine did- remember something about a glass bulb, and rubber parts clogging the lines I took off- maybe the return fuel line? Replacement parts last much longer. Would restart and run for a while. Diesel Specialties diagnosed it over the phone, gave me a price, and stuck with it- sent all the old parts back. Works perfectly since then. If someone else does it cheaper- ok. but I was satisfied. BTW- I"ve always been impressed with the advice you give to everyone on this board. Like Bob, you are one of the "go to" people. Extremely knowledgeable.
