1935 JD A oil pressure
Vern H
04-06-2008 16:31:36
Greetings,
Had low oil pressure and was told it was internally adjustable. I found the top of filter canister was distorted and leaking pressure. The ball check in the filter head looks to me like a system to keep the the oil from draining out of the engine, not an adjustment. Any comments?
thanks. VH
Great pressure after repairing canister.
DGK
04-06-2008 18:21:57
 Re: 1935 JD A oil pressure in reply to Vern H, 04-06-2008 16:31:36
Vern 35 A"S have oil pump behind flywheel, not in crankcase.
Vern H
04-07-2008 10:42:59
 Re: 1935 JD A oil pressure in reply to DGK, 04-06-2008 18:21:57
DGK
Thanks for the comment.I did find new oil pump gears which helped even before I repaired the filter canister. Now I can bounce the redhead with the flywheel. VH
