4010 touchy brakes
c.w ny
04-06-2008 16:08:55
allright the brakes on my 4010 are touchy they only have one position "locked up" when you put ur foot on the brake . i have bleed the brakes several times, i cant get hard pedal either , it makes for fun times going down the road gota start to slow down a ways before you plan on stopping, any ideas
c.w n.y
04-07-2008 14:28:55
 Re: 4010 touchy brakes in reply to c.w ny, 04-06-2008 16:08:55
thanks for the leads, now i have some clues to go on anyway. Ill have to look into it somemore i really look like a twit when i lock the brakes up going down the road. Not to mention hard on the tires.
wreutelh
06-03-2008 09:19:39
 Re: 4010 touchy brakes in reply to c.w n.y, 04-07-2008 14:28:55
Did you ever get a resolution to this problem with your 4010? I have the same issue with mine. Did you find a rebuild kit for the mastercylinder? TIA Eric
mattd
04-07-2008 10:28:32
what does the rubber boots look like. if they are cracked or missing then rebuild the entire brake valve and put new boots on.
DONMYEIL
04-07-2008 06:22:31
I think there was a factory modification for that. I have a bad case of CRS syndrome and cant remember what we did. might check the old parts book and compare insides. or the easiest thing would be to go to a salvage yard and get a 4020 valve. Just a thought, DON
msb
04-06-2008 21:19:25
Nature of the beast. The 4020 brake valve has an equalizer valve that eliminates a lot of that grabbing.
