50 axle paint
PreciseFarms
04-06-2008 11:01:05
What color, if any should I paint the axles (rear of course) on a model 50. I was thinking about flat black but I didn't know if of you knew better. I'm at the point where I'm ready to put the rear wheels on. Thanks in advance.
johns48jdb
04-07-2008 17:02:20
 Re: 50 axle paint in reply to PreciseFarms, 04-06-2008 11:01:05
according to green magazine and two cylinder they will accept tractors at show that have the inside portion of the axles painted flat black and the out side end left unpainted. i use silicone spray to coat the outer ends to hold down rust. one or two coatings a year and they never rust. if you really want to raise a stink, put grease on the outside end and cover with a burlap back and wire it on. its in the owners manual or service manual for my 48 b.
J Chantry
04-06-2008 18:17:10
I agree with F-I-T. Painted my 40 axles with blitz black from JD. Looks good and stops the rust.
PBrowning
04-06-2008 14:11:29
Strip away the primer coat, clean & dry, and apply Deere TY25797 Graphite Lubricant. This is in aerosol form, easy to use. It coats, lubes, and brings out a kind a blue-black color -- pleasing to the eye, and good protection for the axle. You will never have to worry about the hub seizing up on the axle again either. A year or two later, reapply as needed without concern for coating build-up! This works for the Texas Shorthorn! (PatB)
buickanddeere
04-06-2008 11:20:40
Cold blueing for rifle barrels works well. Doesn't bind when adjusting width either. Factory didn't paint axles unless you count overspray.
PreciseFarms
04-06-2008 11:50:29
 Re: 50 axle paint in reply to buickanddeere, 04-06-2008 11:20:40
Thats great, the previous owner had already primed them...any suggestions?
F-I-T
04-06-2008 12:17:39
 Re: 50 axle paint in reply to PreciseFarms, 04-06-2008 11:50:29
If they're already primed, semi-gloss black, or under the Deere name, "Blitz Black", is pretty much a universally accepted alternative to the natural finish from the factory. "Universally accepted" meaning that it's your tractor and you can paint 'em pink if you want, but no one should pitch a fit if you exhibit black axles at a show. Lots of 'em have semi-gloss axles for rust prevention and ease of cleaning.
IMHO
Frank
PreciseFarms
04-06-2008 18:41:51
 Re: 50 axle paint in reply to F-I-T, 04-06-2008 12:17:39
Thanks a lot. Blitz Black was where my mind was going but its nice to have some reassurance. The graphite spray lube didn't sound too bad either though. Probably will go w/ the paint though. Like you all, I was pretty sure Deere did nothing with regard to painting the axles at the factory, but somehow they always stay looking pretty good all things considered.
Handsome Jim
04-11-2008 19:35:15
 Re: 50 axle paint in reply to PreciseFarms, 04-06-2008 18:41:51
ok
Handsome Jim
04-11-2008 19:35:13
ok
F-I-T
04-07-2008 04:00:14
I would not recommend putting any sort of lubricant on a joint such as this that depends on a interference taper and friction to stay put. Make that axle slippery and you can expect that the wheel will creep as you make turns. A few years ago, one of the fellows here used graphite on his F1500 wheel assembly, including the wedge surfaces, and the lack of resistance allowed the wedge to be drawn in too far with the same torque (which is why you have lubed and unlubed torque values for a fastener) and the wheel cracked from too much wedge pressure. It happened to another fellow not long after. You can probably still find that thread in the archives here about 5 years back. My take: you want to prevent corosion, not lubricate that joint.
