'36 B Piston and Rings
Kris A NC
04-05-2008 15:14:01
I am kinda confused at the moment with my project. When I took my '36 B apart everything looked to be original, block and pistons etc. I didn't see any part numbers on the piston or indication of being over-sized. I thought I read somewhere that the over size amount was stamped in the top of the piston. I didn't not see this. I just got my block back from being sleeved. He had the pistons with him and bored the sleeve to match the pistons. When I went to fit my rings today I put the ring in the bottom of the cylinder and could fit two quarters between the gap in the ring ends if I tried. I ordered standard bore rings. Now I don't know what to do. How can I know for sure if my pistons are standard pistons? Where are the part numbers located on pistons? I know now I should have measured the piston prior to ordering, but I don't have the measuring equipment to do that. Now I am just at a lose on what to do. Did I miss something or do I have to get different rings? The rings I got were AB2522R. Any and all help is greatly appreciated.
Kris A NC
d. coleman
04-06-2008 17:11:14
 Re: '36 B Piston and Rings in reply to Kris A NC, 04-05-2008 15:14:01
know all about bad days, 3 out of 6 helicopters grounded for stupid pilot screw-ups and oil company screaming at maint. to get them going with no parts. anyway im interested in finding out the outcome of your delima. when you stated ring gap of two quarters(coins) i was thinking that was excessive even for a .045 oversize verises standard bore that is what got me thinking about the different year tractor bore size, but as you i was having a bad night and using the forum as a get my mind off stupid pilot screw ups. to bad i failed to consentrate on my postings and listed my friends "A" bore size whch we have been tearing down for smokeing dignoise. post what your outcome is. good luck, d. coleman
Kris A NC
04-06-2008 18:50:10
 Re: '36 B Piston and Rings in reply to d. coleman, 04-06-2008 17:11:14
Sorry to hear of your bad day as well. Hopefully this week will be better for both of us. I will post in a new post what my findings are. Thanks!!
Kris A NC
Mike M
04-06-2008 13:25:35
STD. bore on one of those should be 4.250" if I'm not mistaken. I was also thinking on the unstyled they may of offered .030" oversize ? and that is what my B has.
Kris A NC
04-06-2008 13:33:00
 Re: '36 B Piston and Rings in reply to Mike M, 04-06-2008 13:25:35
After looking in the parts manual you are correct they did offer a .030 over-sized ring set, but I see no reference to the .030 pistons. I find that odd, but yes that is another possibility. I hope that is not the case for me as they are no longer valid, at least with the part number i have. (AB1055R). Thanks for bringing that up Mike M!
Kris A NC
PBrowning
04-06-2008 14:16:37
 Re: '36 B Piston and Rings in reply to Kris A NC, 04-06-2008 13:33:00
Kris -- There are rings of almost any dimension you can imagine. Do not panic. Once you have determined what you have, and there remains no doubt, give Russ a call over at Heartland Tractor and give him a crack at finding you what is needed here. He won't jive you -- eithe he can help or he can't -- he is honest! (816) 587-4747.
The key to success is "no more guessing". Measure several times so as to be dead certain, then go for it! (PatB)
Kris A NC
04-06-2008 16:11:40
 Re: '36 B Piston and Rings in reply to PBrowning, 04-06-2008 14:16:37
Call it my young ambition and slimming patience of hearing this 'ole girl run. I appreciate your input Pat and respect your knowledge. I will get them measured and I will get whats needed. Trust me, next time there will be a good measurement. Lesson learned!
Kris A NC
PBrowning
04-06-2008 16:59:15
 Re: '36 B Piston and Rings in reply to Kris A NC, 04-06-2008 16:11:40
Kris -- are you ready for a good read? One where far too many assumpptions were made? The go to the URL below and select "Engine Build-up". When we try to cut a few corners, a brick wall may be our next stop! Enjoy! (PatB)
Kris A NC
04-06-2008 17:40:51
 Re: '36 B Piston and Rings in reply to PBrowning, 04-06-2008 16:59:15
Pat, that is a good right up. I have read it before, but sometimes a reread is necessary. Thank you!!
Kris A NC
Kris A NC
04-06-2008 09:11:38
Thanks Guys for all your help. From what I have come up with Deere didn't offer anything but .045 over pistons. My are cast iron and have JD on the inside. The standard rings are too small so with that logic, they would be .045 over. I am having my brother come over today with a Dial Caliper to get the exact size. Then we will get the correct rings. Anyone need a set of Standard rings??? LOL Have a great day!
Kris A NC
D. COLEMAN
04-05-2008 22:55:51
OOPS. HIT 5 INSTEAD OF 4, GUESS I HAD BETTER DOUBLE CHECK MY POST PRIOR TO SENDING , GOOD NIGHT TO ALL, IVE WORKED ON ENOUGH HELICOPTERS FOR THE NIGHT AND ITS TIME FOR A COOL BEVERAGE.
d. coleman
04-05-2008 20:52:38
will p. double check your post,i posted .020 &.040, not .20 d. coleman
Will P
04-05-2008 21:01:36
 Re: '36 B Piston and Rings in reply to d. coleman, 04-05-2008 20:52:38
Deere had only .045 pistons available for the B.
Will
d. coleman
04-05-2008 20:32:53
not on unstyled "B", i have a 51 styled "B" and my books only show a .020 &.040 also my 48 "M" only shows the same .020 & .040 oversize avaiable. sence the early "B" hade a 5.5" bore and the later styled "B" hade a 5 and 11/16 inch bore could the previous owner have installed wronge year pistons? didnt mean to step on any toes about manuals, just sounded like you had no information in your first comments. im at work out of state right now and dont have access to my manuals for p/n's good luck d. coleman
Will P
04-05-2008 21:25:17
 Re: '36 B Piston and Rings in reply to d. coleman, 04-05-2008 20:32:53
5.5 bore?? 5 11/16 bore??? What B are you working on????? ??? His B is 4 1/4. My 43B is 4 1/2, and your B is 4 11/16
Will
Kris A NC
04-05-2008 20:53:04
No sweat there Mr. Coleman. Its just a frustrating time for me since I wanted the tractor ready for a show next weekend and now that probably won't happen. I shouldn't have come back the way I did either. I apologize for that. The original bore on the '36 was 4 1/4" and stroke was 5 1/4". They are a far cry from the late styled 5 11/16 as you stated. The block is the correct block for the year so they have to be over-sized pistons. We'll see what my measurements come up with tomorrow I guess. On top of all that, I attempted to get the push rod tubes out tonight in my "down time" and I striped the threads on my all thread that I got from Lowes. I tapped the push rod tubes and then sent all thread down in them with a larger diameter pipe for "brace" with a washer on top and a nut. You can see how the threads on the all thread just smoothed right out. Just been a bad day in my tractor world for me. Hopefully tomorrow will bring new light. Thanks again.
Kris A NC
Will P
04-05-2008 19:09:33
If they are Deere cast iron pistons, the number is inside the piston. If you have cast aluminum pistons, they are not Deere
Kris A NC
04-05-2008 19:43:50
 Re: '36 B Piston and Rings in reply to Will P, 04-05-2008 19:09:33
thanks WillP. They are cast, no doubt. I see what looks like an "R" on the inside. But that is all I can read. So I guess I am out of luck there. I am going to get a Dial Caliper tomorrow so I can get the accurate measurement on the piston. Looks like its new rings I guess, unless someone else can come up with something.
Kris A NC
Will P
04-05-2008 20:00:04
 Re: '36 B Piston and Rings in reply to Kris A NC, 04-05-2008 19:43:50
Use the dial caliper on the inside of the bore and post those readings. Top of the bore and at the bottom too.
Will
Will P
04-05-2008 19:50:14
Put a magnet to the piston and tell me what it does.
Will
Kris A NC
04-05-2008 21:02:29
 Re: '36 B Piston and Rings in reply to Will P, 04-05-2008 19:50:14
sticks to it
Will P
04-05-2008 21:17:20
 Re: '36 B Piston and Rings in reply to Kris A NC, 04-05-2008 21:02:29
They are probably .045 over cast iron pistons. Measure them with your caliper will probably tell you that. You have standard rings? My 51G had blowby, someone put standard rings on the aluminum aftermarket .090 over pistons. Had a ring gap of over .300
Will
DanL-Colorado B36320
04-05-2008 16:51:08
 Re: '36 B Piston and Rings in reply to glsinNY, 04-05-2008 15:14:01
Call your machine shop. They had to measure the pistons before they finished the cylinders; if they have a record of the measurement they can tell you the size of the pistons.
D. COLEMAN
04-05-2008 16:33:31
i would make sure the pistons are john deere and not aftermaket prior to reodering rings, if im not mistaken, jd only offered pistons in .020 and .040 oversize. anything larger was aftermarket also the ring withe will be different. a shop manual and parts manual and owners manual is well worth the money prior to starting a major job. a good mech. shop should have asked for the eng. specs. prior to starting the work. good luck.
Will P
04-05-2008 19:08:22
 Re: '36 B Piston and Rings in reply to D. COLEMAN, 04-05-2008 16:33:31
John Deere only offered standard and .045 over!!! Not .20 or even .04
Will P
04-05-2008 21:19:56
 Re: '36 B Piston and Rings in reply to Will P, 04-05-2008 19:08:22
opps .02 and .04
Kris A NC
04-05-2008 17:33:45
Mr. Coleman,
Thank you for your insight. I have an owners manual, parts manual and for the unstyled they didn't make a service manual although I have heard the SM-2004 is close enough for the unstyled tractors. I have read the owners manual, but have failed to see where it tells me about proper piston ring gap and where part numbers are located on the pistons or any other information that would help me out in this situation. I do not have the SM-2004 however. Do you have part numbers for the .020 and .040 pistons? Can you tell me where the part numbers are located? Thanks,
Kris A NC
James P.
04-06-2008 17:57:56
 Re: '36 B Piston and Rings in reply to Kris A NC, 04-05-2008 17:33:45
If they are oversize pistons the casting numbers on the inside of the piston on the bottom inner lip will be ground off. Part # should be stamped in top of piston along with whether it is std. or if oversize it will have size. Usually it is at the outer edge on top of piston. Maybe this will help. JP
