pto problem?
backwoodsfarm
04-04-2008 21:08:03
Hello all. Went out to the barn this morning to move the 4240. Started it up, got out of the cab to move some other things and noticed the pto shaft was spinning. Moved the pto lever up and down a few times, checked it and it was still spinning. Got in, moved it out of the barn and when I got out the pto had stopped. I engaged and disengaged it several times and it appeared to work normal. Tried it again this afternoon and it did the same exact thing. Quad-range transmission. Have several high houred 40 series but never seen this before. Any thoughts?
backwoodsfarm
04-05-2008 05:30:44
 Re: pto problem? in reply to backwoodsfarm, 04-04-2008 21:08:03
Outside air temp. was in the upper 30's. April is spring service month for us so the filters and such haven't been changed since last August. Probably had 100-125 hours on this one since then. Probably only a couple of hours on it since January though. I hope a filter and some warm weather will fix it!!
d. coleman
04-04-2008 21:24:56
just an idea, what about the outside air temp? is there a chanch it cold weather related? what about trash or debrie build up behind the leaver not allowing it to disingauge all the way untill it was operated several times causing debrie to be dislogged. just a thought, good luck, d. coleman
