1952 A fluid levels
The JD Workmen
04-04-2008 18:52:30
We have the manuels on the way but we wanted to get the fluids changed on our A this weekend. the s/n is 290602. We need to know the fluid capacity for the crankcase,transmission, first reduction gear cover,power trowl and cooling system. Thank You!
The JD Workmen
04-05-2008 09:05:40
 Re: 1952 A fluid levels in reply to The JD Workmen, 04-04-2008 18:52:30
Thanks for the help I appreciate it.
The JD Workmen
04-05-2008 19:26:09
 Re: 1952 A fluid levels in reply to The JD Workmen, 04-05-2008 09:05:40
sorry about that 690602
Pappy
04-04-2008 23:37:42
The primary reduction gear cover should get one pint of engine oil. I believe your's would have a drain plug on the bottom of the cover.
CLW
04-04-2008 19:36:29
Check your serial number. The 52 starts with 682602. If it is a 52 then:
Cooling System = 8 1/2 gal.
Crankcase = 11 qts.
Trans. and Diff. = 27 qts.
fixerupper
04-05-2008 17:18:39
 Re: 1952 A fluid levels in reply to CLW, 04-04-2008 19:36:29
Do you mean 1952? My 1951 A, Ser. 685840 has a warehouse date of 9/11/51. Jim
PBrowning
04-05-2008 17:38:35
 Re: 1952 A fluid levels in reply to fixerupper, 04-05-2008 17:18:39
Your "A" tractor, S/N 685840 is a 1952 production year tractor. 1952 production began with s/n 682602. Production years and calendar years are not the same thing. (PatB)
Jon Hurley
04-04-2008 19:35:51
I let my manual go when I sold my A. But the following is from the I&T manual
crankcase: 11 quarts
transmission & diff: 27 quarts
cooling: 8 1/2 gallons
If I remember correctly the first reduction gear cover took a quart or two. The power-trol was about 4 quarts.
Hope this helps.
