john deere b
720diesel
04-04-2008 17:49:43
I need the torque for the block, head, and connecting rods. I also need the clearances for the rod bearings.The tractor is a 1948 John Deere B. Thanks!
PBrowning
04-04-2008 20:25:08
 Re: john deere b in reply to 720diesel, 04-04-2008 17:49:43
Set connecting rod bolts to 75 ft-lb, then tighten as needed to insert cotter.
Set Running Clearance from 0.001 to 0.003-inch. Thickness of the thinest shim is 0.003".
1150 in-lbs for cylinder head is right, and
125 ft-lbs for cylinder block-to-case is good.
(PatB)
EdM
04-04-2008 18:11:46
Torque for block to case is 1500 inch pounds.
Cylinder head to block is 1150 inch pounds.
Connecting rods...all I can find is to tighten the nuts securly and put in cotter pins.
Connecting rod bearing oil clearance is .003 inch.
