Block Boring
twincreeks
04-04-2008 16:34:16
What is the going price to get a JD G bored .45 or .90. Just trying to get an idea what is going to cost.
kendak
04-05-2008 17:25:51
 Re: Block Boring in reply to twincreeks, 04-04-2008 16:34:16
Cook Machine Shop in Memphis, TN. does the work on my pulling tractors ...just bored a unstyled "A" block .250 $100. a hole...does top notch head & block work...Kent
D. COLEMAN
04-05-2008 15:19:44
I CHECKED ON A "M" BLOCK AT A PENSACOLA,FL. MACH. SHOP. THEY QUOTED ME $30.00 A CYLINDER HOLE AND $45.00 TO SERFACE MILL, $25.00 TO INSTALL CAM BEARINGS (I GET ALL PARTS) AND $75.00 FOR HOT TANK AND FREEZE PLUG.
Larry806
04-05-2008 13:02:18
My son bored 5 D blocks last year for 1 guy . They were cut 250 ths , he charged 350 each .
buickanddeere
04-05-2008 09:50:19
That should have included pistons and rings as well.
960
04-05-2008 09:08:45
I had a late A block done .045 last summer in central IL for $500. I am a repeat customer at that fine shop and will return. Inflation will have probably raised the current price.
Drew
04-05-2008 12:07:10
 Re: Block Boring in reply to 960, 04-05-2008 09:08:45
I still think that is about 2x what it should cost. I guess maybe some shops just charge a lot more when it is something out of the ordinary and they have to think harder????
Dandy Dave
04-05-2008 05:26:59
Somebody has their decimals in the wrong place. :shock: Should be read .090 or .045. :) Dandy Dave!
gold-leaf-deere
04-04-2008 20:31:00
I sent a D block and head to ATLAS Machine in Louisville, Kentucky last year. The block was stock 6 and 3/4 inch. It was bored to 7 Inch. The head was milled just enough to make it flat. When I got them back a bill was with them for $1600. advised them that they just bought a head and block. They made a counter offer of $1200, I paid them , but I still fell like I got ripped offf.
PBrowning
04-05-2008 05:38:55
 Re: Block Boring in reply to gold-leaf-deere, 04-04-2008 20:31:00
Good morning to you and yours in Evansville! Are you getting enough rain? It's good to see you on the board.
Now -- even at $1200, I hold that you should have had two sets done for that amount! Now, I realize some jobs require a touch more effort than others, but I am accustomed to getting a block overbore and head overhaul (H tractor) for under $300, usually well under. Granted it has now been over a year since my last one and prices are rising, but there has to be a point where "enough is enough".
My advice -- Shop around, and get a hard quote beforehand! And don't miss getting a quote from Russ Schworer of Paul's Rod & Bearing -- Fine man!
Pat, The Texas Shorthorn (PatB)
THE SMOOTHED DEERES
04-05-2008 05:12:28
Gold Leaf ,we are about in the same price range .Spent 1,200 for the engine work on a B .
KJF470
04-04-2008 20:22:46
Is there really that much material in the G blocks to take out .900"? Isn't that almost an inch? 900 thousandths is alot !
jd b puller
04-04-2008 16:45:33
 Re: Block Boring in reply to Dave in SV, 04-04-2008 16:34:16
Shouldn't cost you more than $200-$250. Make sure the guy doesn't think it's a small block Chevy. Many shops can't bore or hone above 5". Put your location in and someone probably knows someone close to where you are.
F-I-T
04-04-2008 17:02:10
 Re: Block Boring in reply to jd b puller, 04-04-2008 16:45:33
It's not just the bore diameter, but also the length of the bore to machine as well. Be sure to tell them both measurements when you start calling around so they can determine if their boring equipment can handle before you make a trip.
NavyChief
04-05-2008 08:08:03
 Re: Block Boring in reply to F-I-T, 04-04-2008 17:02:10
I just got my G block and crank back from Center automotive in Canton, Ohio, and my whole bill for a .125" over bore, block decking(.003) and to have the crank turned, was only $552.00.
R/
Eric
PS Frank, I LOVE THAT LYE GRAVY!!!!!
F-I-T
04-05-2008 19:04:24
 Re: Block Boring in reply to NavyChief, 04-05-2008 08:08:03
Pretty cheap for what it does, isn't it? :)
