1941 45 B Fan-shaft assembly
Gary from Mules
04-04-2008 16:03:21
Is the fan-shaft assembly from a 1945 B the same as a 1941 B?
Gary from Muleshoe
04-04-2008 17:15:04
 Re: 1941 45 B Fan-shaft assembly in reply to Gary from Muleshoe, 04-04-2008 16:03:21
Thanks for the information. This is for a friend's tractor he had the old pressed on type and the fan worked loose and went through the radiator. He will appreciate the help also.
Gary
Mike M
04-04-2008 16:54:57
It might have the newer type fan hub with friction disks which should be a better set up than the 1 pc. hub with rubber insides. And I agree with the other fellow it should fit and also get the matching gear out of the gov. if you also need gears. Or change yours so they match. These are best set up on a workbench with the fan pointing straight up in the air. The JD service manual on the B shows this in great detail.
Mark-IA
04-04-2008 16:41:53
You should take your old gear off and install it on the other shaft, as the gears are a mated set.Might howl. Don't lose your shim gaskets.
Mark-IA
04-04-2008 16:40:17
yes
