18hp john deere runs rough
rafael
04-04-2008 05:44:15
have a 18hp john deere tractor that runs rough have to have full chock to keep it running and then fouls plug pretty easy and have to play with chock to keep running
jd b puller
04-04-2008 16:47:52
 Re: 18hp john deere runs rough in reply to WJGreenlees, 04-04-2008 05:44:15
Rafael, pretty tough to diagnose a problem if you don't know what it is your working on. Kohler is different from a Briggs, Kawasaki, etc.
What model tractor, which engine, how many hours, how long has it done this, etc...
buickanddeere
04-04-2008 06:49:31
 Re: 18hp john deere runs rough in reply to rafael, 04-04-2008 05:44:15
Some details would be of assistance. Data such as lawn/garden tractor model, engine manufacture, air or water cooled, single or twin cylinder, single or twin barrel carb.
Did the problem appear suddenly or gradual? Is the engine thermostat working? Are you cleaning the plug or replacing it? A weak ignition coil can cause these symptoms too.
A miss adjusted or plugged crankcase breather can cause plug fouling. It's choked not chocked
Dave H
04-04-2008 06:24:33
I would try to find the fuel starvation problem. If it were me I would pull the fuel line at the carb and crank it and see it it is pumping fuel. Check the fuel filter?
Be careful and prepared about starting fires
