JD 110 with K241 AS
BD Baker
04-03-2008 19:57:14
Bob,
I forgot to ask how far the governor crossshaft is supposed to turn counter clockwise. When I tried it the first time it rotated about a 1/4 turn or less. Is that about right? Thanks for your help.
buickanddeere
04-04-2008 16:00:23
 Re: JD 110 with K241 AS in reply to BD Baker, 04-03-2008 19:57:14
Some of those Kohlers had plastic govener gears. With time or if the engine was ever wound above 4000rpm. They break.
Ask me why I have to replace a rod on my son's 110.
buck eye al
04-04-2008 14:12:54
-Not running, set the throttle lever on the dash so that the linkage is holding the carburetor's throttle plate wide open. If your governor linkage is badly out of adjustment it may not reach Wide Open Throttle (WOT). If not, don't worry yet! -Loosen the clamp bolt holding the governor arm to the governor cross shaft. NOW carb should definitely go to WOT in case it did not before you loosened the clamp. - While making sure the carb remains wide open, rotate the cross shaft counter closkwise as far as it will go and tighten the clamp bolt.
