D experts - another request
JGC
04-03-2008 03:51:21
RE: DLTX-16 Carb.
There is a small orifice at the throttle disk that the manual refers to as the "primary idle orifice". It is drilled on an angle. Do you know what diameter in should be. It appears to be restricted by a crusty deposit. I can clean it out with "number" drill bits but I don't want to make it too large. It is difficult to tell for sure but it looks like it may have a calibrated orfice pressed into the opening, or it may just be scale build-up.
Thanks in advance for your assistance!
Jon
wilamayb
04-03-2008 04:42:30
 Re: D experts - another request in reply to JGC, 04-03-2008 03:51:21
I"m not sure of the actual size, but generally you can clean that opening with torch tip cleaners if it is crusty. Be sure that you get all of the crud out of the passage on the outside of the bore once it is pushed in.
