2510 hydraulics
Adam Coombs
04-02-2008 19:04:29
have a 2510 that the hydraulics chatter, pulse,and are slow to operate when they are cold.
have changed the fluid and filter. any ideas?
jdemaris
04-03-2008 06:54:53
 Re: 2510 hydraulics in reply to Adam Coombs, 04-02-2008 19:04:29
Probly needs a new stroke-control valve in the pump - it's a common wear item. You can install a new one without removing the pump.
When they get worn, they chatter like crazy until you start to use a hydraulic function. Then can also make the tractor start very hard in cold weather.
matthies
04-02-2008 19:32:05
Did you happen to check the suction screen? And have you installed a check valve in the suction line of the pump?
Bob
04-02-2008 19:10:09
Start by checking transmission pump flow. If you are goning to troubleshoot this thing yourself, a "flowrater" and a factory shop manual are "must haves".
