B gas tank removal?
TJ in IN
04-02-2008 18:41:52
Trying to remove my rusty gas tank for my late model styled B. Seems the steering rod needs to come forward through the steering pedistal to get the hood off. But I'm having trouble figuring out how to get it out. What's the trick?
James Howell
04-03-2008 17:48:37
 Re: B gas tank removal? in reply to TJ in IN, 04-02-2008 18:41:52
I agree with Ron on steps to remove the gas tank.
Look at the "black hole" on the top of the pedestal of "Lazarus" my 40B.
third party image
The steering shaft will come out through this "hole" once you remove the end cap.
There is a worm gear on the end of the steering shaft so you will have to "twist" the steering shaft to work it out.
I also agree with Ron and Johns48jdb about replacing the muffler and cleaning the air stack.
I have done both on "Uncle Earl" my 39B.
The link below will show some additional photos of what I did to "Uncle Earl's" gas tank.
Hope this helps.
johns48jdb
04-03-2008 04:26:35
while your there remove the air cleaning stack and give it a good cleaning out. soaking it in gas is a good start. be careful where you set the open container. outside is best. if you clean the air cleaner out real good you'll find a weep hole in the bottom of the housing that allows water to run out if any gets in through the inlet pipe. its stopped up so you may have to dig a little to find it. if the wiring is in bad shape now is the time to repalce it too. watch your wiring as you come out. i'd disconnect the battery to start with.
Ron Taylor
04-02-2008 19:14:04
The grill & nose piece come off 1st,then the cap on the front of steering pedestal,then the steering wheel.turn steering shaft & it will unscrew from the gear.The hood & tank both have to come off as 1 unit.I sugestSTRONGLY to put on a new muffler before you put it back together because this is the only way to get to the muffler unless you cut a big hole in the hood like 90% of them did.Have fun.
