D Experts - help requested
JGC
04-02-2008 18:16:15
What is the best float height and fuel level for the DLTX-16 carb on a JD model "D" ?
The JD engine manual that I have is very generic. It says 3/8" float level (measured by inverting the bowl) and 3/4" fuel level below the bowl rim measured using fuel and a clear sight-tube after the carb is assembled.
Sometimes experience is better than the guidelines in the manual!
Thanks in advance for your assistance!
Jon
Mike M
04-03-2008 10:10:51
 Re: D Experts - help requested in reply to JGC, 04-02-2008 18:16:15
Some of the late A and B carbs. they want that 3/8" inverted measurement. In the real work conditions that also makes them blow black smoke when you hit a bump so I set them to 1/2" like the earlier models were to be. I'd set yours to 1/2" or 7/16" and see how it runs.
Duane Larson
04-02-2008 18:43:55
Jon,
Your manual is correct. I always measure the fuel level with the 1/8" hose barb and plastic tubing to make sure it is 3/4" from the top of the bowl.
JGC
04-02-2008 19:03:52
 Re: D Experts - help requested in reply to Duane Larson, 04-02-2008 18:43:55
Thanks Duane!
Jon
