Comments about JD 450C Crawler
Steve Eberly
04-02-2008 11:46:34
I am looking to buy one for part time fence row work at my place. Anyone know of any things to look out for in a used machine?
cummins
04-16-2008 19:06:57
 Re: Comments about JD 450C Crawler in reply to Steve Eberly, 04-02-2008 11:46:34
yes Im looking a buying a 450C with a hole in the block its a none turbo crawler he has a complete engine from 450G with turbo engine model #4276T does any know if this engine will work
Thanks
Roy Suomi
04-03-2008 13:58:46
Hey gurneejoe...Since when did Deere put dry clutches in a "C"????? Straights and "B"s had dry clutches....Where do you buy parts for an IH?? I've got no where here in NE ohio...
gurneejoe
04-02-2008 19:34:06
My advice is to look for an international 100E or 125E crawler with a 4in1 bucket. I was a mechanic for IH and we did many time studies on maintenance for the factory at our dealership and I can tell you that these machines are pretty much bullet proof as far as reliability. They have wet steering clutches that cannot be destroyed even by a novice operator and can be steered with one finger. The engine is a Deutz German diesel (the 125 is turbocharged)They have self leveling bucket hydraulics and nitrogen accumulators in the boom hydraulics to save your back when the boom drops down fast and is stopped short of the ground. I have worked on the JD machines and the steering cluth system is a nightmare of linkage and adjustments that when all is said and done is a pair of throwout bearings and dry automotive type clutches that have a very long lever throw and are hard to pull. A day on one and you will have sore arms you won't forget. I will tell you that I am a loyal JD lover and have gotten a lot from this forum with my A project but belive me about these machines. Find one and drive one and you will be amazed at the difference in the JD to the IH crawlwers of that size. The newer ones are dresser models but they are the same inside.
Roy Suomi
04-02-2008 14:08:24
Check how the transmission shifts..If properly adjusted , you should be able to shift from high to reverse in second gear without snapping your neck at wide open throttle..Same going from reverse to high forward..Try it at lower rpms and gradually speed the engine up and try again..On the forward to reverse shift it should just "suck" you off the seat back..No faster not much slower..If trans can't be adjusted by a competent mechanic..If it shifts too slowly, it will heat the transmission from slippage..I suggest taking a Deere T-19044 oil filter with you and change the filter inside the grill..Take that filter somewhere to cut it apart..Cut out a piece of pleated paper element and inspect it for "nasties"[ brass , steel , burnt oil].. Check the clutch housing for broken or missing bolts thru the side engine frame rails and underneath the frame rails.. Look for broken engine frame rails back by the steering clutch housings..Abuse shows up there..I've had no luck welding these rails..The rails will crack next to your weld..Something about the metalurgy that seems to make repairs impossible.. Look for gray or milky motor oil..Look for pressurizing cooling system..These indicate cylinder liner or oil cooler problems...On a push , pull back both steering clutch levers , then release them ..Do the tracks take right off and continue to push??Poorly adjusted steering valve spools , or leaking steering clutch piston , manifolds.. Or low oil pressure in the transmission.. How about broken bolts at the front crossbar and at the rear crossbar..How about undercarriage ?? Rollers , sprockets , chains , idlers..Boy , What did I miss ?? These are the "Bread and Butter" machines of Deere...There were Zillions made and they were a darned fine machine, provided they weren't beat to death and partially resurected enough to make due.. Keep your eyes open and ask questions, ask for repair records if any..Ask someone to go with you that knows machines well..Good Luck..
jdemaris
04-02-2008 14:05:40
Other than the things you'd normally check on any crawler - with the 450C a few specifics. Get it good and hot - and then verify the trans does not slip - and the engine holds oil pressure at low RPMs. Often, when an HL-R trans starts to go, it only shows up when good and hot. At that point - many get "for sale" signs on them, and are sold as-is. With the engine, often in-frame motor jobs are done without renewing the balancing shafts and bushings. When loose, and engine can have good oil pressure when cold, and go down to zero once good and got at low speeds.
