1020 won't start, really puzzled?
David C
04-01-2008 20:37:50
I have a 1020 we have had for 20 years. It has always started right up. Here recently it has been acting up. It will not start for days. It will turn over just fine, you can smell un-burnt fuel, and there is spark every time I have checked it. Sometimes you will get a few fires but most of the time it just turns over and over. Then one totally random on how long it won't start it will fire right up like it was brand new. It will run for hours but if you shut it off it may or may not start again. Any suggestions. Thanks in advance
Bob Nelson
04-02-2008 17:43:13
 Re: 1020 won't start, really puzzled? in reply to David C, 04-01-2008 20:37:50
If you disconnect the solenoid, remove the needle, and reverse it, you can bypass the solenoid.
RobMD
04-01-2008 21:07:53
They had problems with the fuel shut off solenoid on the bottom of the carbs.
David C
04-01-2008 21:12:19
 Re: 1020 won't start, really puzzled? in reply to RobMD, 04-01-2008 21:07:53
Yeah I saw some posts about that. Is there anyway to test it or bypass it?
Bob
04-01-2008 23:57:28
 Re: 1020 won't start, really puzzled? in reply to David C, 04-01-2008 21:12:19
You can verify battery voltage is getting to the shutoff solenoid with a test light, and you should be able to hear/feel it snap open when the ignition is switched "ON".
RobMD
04-02-2008 14:13:44
 Re: 1020 won't start, really puzzled? in reply to Bob, 04-01-2008 23:57:28
I recall having a 1020 at my high school way back when, and the solenoid would be an intermittent problem, cutting in and out as you would be driving along.
Come to think of it, they never did get it right.
