1958 520--Broken Ex. Man Stud--need repair advice
Tbolt76
04-01-2008 20:11:28
My tractor has a broken stud mounting the Ex. manifold on the right side to the head (rear stud). The stud is broken off at the head/manifold interface, and gasket is blown out. I'm trying to determine from my JD50 service manual how much time this will take i.e. remove hood/ventilator pump/fan shaft etc. I think I might have to drill out the stud if I cant heat or weld nut onto it to remove. The other option is to use some hight temp exhaust repair stuff as a temp fix. Also, the exhaust pipe is rotted where it goes thru the muffler mounting block, all 4 studs are broke off there too. This is a working tractor and I need to decide when to fix, now or end of the growing season. Thanks for the advice in advance. Tom
buickanddeere
04-02-2008 13:59:30
 Re: 1958 520--Broken Ex. Man Stud--need repair advice in reply to Tbolt76, 04-01-2008 20:11:28
How many hours on the engine? It's not a bad job to unbolt the head and slide it off the block. Allows easy access to those busted studs.
Also allows inspection for broken ring scratches and measuring the bore for wear/out of round.
New valve guides and hardened exhaust valve seats are quit reasonable in price.
Thos also allows an opportunity to surface grind the mating surface flat/square for the manifolds. Did the one on the 60 as there was no way the new gaskets would hold for any period of time before blowing out.
ABC1
05-22-2008 15:03:15
 Re: 1958 520--Broken Ex. Man Stud--need repair advice in reply to buickanddeere, 04-02-2008 13:59:30
I am going through a 60 now, getting ready to bore and resurface the block. Can the 60 head studs be removed easily? Also exactly where shoul I be checking for these notorious block cracks.
Mark-IA
04-01-2008 20:56:33
You don't need to remove the hood and ect. Just cut off the nuts on the remaning studs, the pry the manifold up. With the manifold raised up, cut the studs off with a hacksaw, with a 1/4" remaining. Pull the manifold out. You can then heat the studs and weld a nut on them to screw them out.
bigblock
04-01-2008 20:16:37
I had to drill all mine out.All of them broke off flush!Then had to helicoil them.
