Electrical System and Mag/Ignition?
Bob Landers
03-31-2008 12:25:33
I"m restoring a 1949 Model B. It"s a mess--lots of rust, engine stuck, battery & alternator missing, distributor but no coil. I"m not working towards a 100% restoration--just want the old girl up and running and looking good.
My question is: since the electrical system is mostly missing, should I go back to the original 6V or stay with 12V. Would appreciate your opinions. Great forum!!
Mike M
04-01-2008 07:24:16
 Re: Electrical System and Mag/Ignition? in reply to Bob Landers, 03-31-2008 12:25:33
Do you have a Delco dist. or a Wico ? on there now ? Either one will work on 6v or 12v you just need to add an extra resistor for 12v. The Delco unit is by far the best unit and was offered in the parts books for a replacement unit. This is the unit you want for 12v too as tractors with mags. on them the starter can spin them so fast on 12v the impulse doesn't always work right. The Wico XB dist. was problems from brand new according to my old Ag. Mech. instructor who used to work for Deere back then.
Bob Landers
04-01-2008 12:05:56
 Re: Electrical System and Mag/Ignition? in reply to Mike M, 04-01-2008 07:24:16
Thanks Mike! Can you buy a 12 volt coil does not require a resistor?
Mike M
04-02-2008 04:27:43
 Re: Electrical System and Mag/Ignition? in reply to Bob Landers, 04-01-2008 12:05:56
For the Delco yes , but I doubt you will find one for the Wico XB.
A model 50 JD was the same equipment as that B but they were factory 12 volt.
John T
03-31-2008 13:16:03
Okay, its YOUR tractor and your call but heres my opinion:
If originality and/or the Correct Police are major concerns KEEP IT ORIGINAL. Also regardless if a Mag or Wico XB Distributor or even a Delco Distributor any ignition shouldnt cause raised eyebrows too bad from the Correct Police since such were or could be Mother Deere suitable replacements. The Wico XB distributor can be harder n more expensive to get parts for and the Wico X mag can have more energy n be easier to find then the older Wico Model C. YOUR CALL
If none of that matters and you want to make "improvements" its true 12 volts can make for improved cold weather starting and electronic ignition or alternators etc (NOT my preference) can improve things.
BUTTTTT T a lil B in any condition at all ought to start n run just fine at 6 volts even in Winter of you use a good heavy battery and 00 gauge cables
Other then NOT a fan of the Wico XB Distributor Id keep her as original as possible including voltage and a generator system if it were mine.
John T
HossinMe
03-31-2008 13:14:07
My 47A is 12volt,isnt your b? Later Hoss
Bob Landers
04-01-2008 06:30:01
 Re: Electrical System and Mag/Ignition? in reply to HossinMe, 03-31-2008 13:14:07
I assumed that my B (239,164) had been converted to 12V. Cost wise, I guess it would be a lot cheaper to buy an alternator and coil and stay with 12 as opposed to buying a magneto and 6V gen.
