You need to be careful here. The steering actuator valve (the female splines you see with the worn pin hole) is meant to be able to slide fore and aft a small amount during operation. They controlled this by using tight splines so it could slide axially with minimal radial slop, but the hole is elongated a bit so that if the steering wheel shaft is tight in the fore and aft direction in the dash board support, the actuator valve can still move fore and aft. If it cannot, you get no movement in the steering valve arm, it doesn't move the poppet valve fore and aft, and you get no steering assist. You can feel this is you lean inward or rearward on the steering wheel as the valve deflects the arm a small amount. Tighten things up too much, add a little binding in the steering support bushing, and you might end up with no power steering and wondering what to do next. Richard Duane is reproducing those actuator valve sleeves, and he might be making a repair stub for the steering shaft. I have in the past, shortened the old shaft a bit, and drilled a new hole for the pin, and this gives you at least a little bit of fresh splines on the shaft side. I have even mig'd a splined at a time, and filed it back to decent clearance. It really needs to be broached to make proper male splines. Other than a lot of new, repro, and nos parts, that's about all you can do. HTH Frank
