JD 44 plow share obsolete?
woodvue
03-31-2008 07:01:11
third party image
I have a model 44 plow with Scotch Bottoms. Does anyone know of a source for those shares and landsides? According to jdparts they are obsolete. The shares are p/n BC397A and the landsides are 8115A.
Thanks
Steven
Earl -IL
03-31-2008 17:32:05
 Re: JD 44 plow share obsolete? in reply to woodvue, 03-31-2008 07:01:11
Woodvue, The shank that your frog bolts to are they offset ? Maybe 8-10 in cut or 10 - 12 in cut?I am thinking maybe 12 in btms. might work. If you go that way ,go to the NGP312 btm which would be 215 share, 8030A frog and the NGP 212 board.I would like to hear from Kim Primmer for his thoughts on this. He has several of the 44 plow combos. Earl
woodvue
03-31-2008 19:53:40
 Re: JD 44 plow share obsolete? in reply to Earl -IL, 03-31-2008 17:32:05
Yes they are offset. The plow was bought new by my grandfather and probably plowed thousands of acres and I once thought they were bent out, but after checking the p/n's and the manual they are offset. I think 12" stuff would work. What was the idea of the scotch bottom? Dad said they never had the 10" shares on it only the 8". I have about 6-8 worn out ones around. So the share cuts 8" and tears 3-4 inches?
Thanks
Steven
Earl -IL
03-31-2008 20:17:45
 Re: JD 44 plow share obsolete? in reply to woodvue, 03-31-2008 19:53:40
Woodvue,I am interested in your plow. What part of the USA was this used ? I work with Crescent Forge & Shovel. They have been in business since 1902 in Illinois.If you had a good share, we might be able to make some new ones.Email if interested. I would like to see this plow work.Are your moldboards good? Regards, Earl In Illinois
woodvue
03-31-2008 13:42:05
Check that it's only 10". The points on it are BC458A.
woodvue
03-31-2008 11:44:44
It is a 12" cut. I had thought of replacing the scotch with more available general purpose parts, but wasn't sure what's involved. The frog is 8114A (Sub. 8213A).
Steven
buickanddeere
03-31-2008 11:32:38
What part number is the frog? You might cross reference it to another model of plough. Then find shares, shines etc for the other plough(s).
What is the width of cut? I ended up with a 12" plough with 14" replacement parts.
