4250 water pump
penhooker
03-31-2008 05:41:51
i just had the water pump on my 4250 rebuilt as a precautionary measure because i have seen recommendations for this on several post here.my problem is:i now have coolant weeping from weep hole.john deere did the work.whats wrong now?
Kevin Meier
03-31-2008 16:15:28
 Re: 4250 water pump in reply to penhooker, 03-31-2008 05:41:51
That should have a unitized seal inside it if water is coming out he weep hole the seal is failing. You can try to run it for 15 minutes to a half hour to see if the seal will seat in but I doubt that will work.
mattd
03-31-2008 08:45:31
they definately messed the seal up. ive actually seen some people try to put that seal in backwards. that could be. but either way i would take it back to them and tell them to fix it on their time.
Regan
03-31-2008 06:01:40
Sounds like they damaged the seal when it was installed. I dont know if the 4250 uses a ceramic seal or not, but if so it may have cracked.
